TOOLS
Re: TOOLS
mig
VIDEO
VIDEO
Re: TOOLS
since you have a compressor. Good quality ( Craftsman or better ) impact sockets, some universal impact sockets. After this I have 2 BFH, Some Pry Bars, and Oxy Aceteline.
After this you really need a cabinet to keep track and store your tools in. I used to check Kijji and Craigslist as there is always something on there.
As far as cutting and welding. I have a stick welder and it handles all the fabrication I would do myself and much cheaper than a Mig IMO with better penetration. Oxy-Aceteline will heat up those rusted on nuts and bolts so you can get them off. And if you can't get them off with heat, then cut them off with the same torch. Very handy when you need it. I only fire mine up once or twice a year but I would have f-ed up a lot of stuff without them.
Re: TOOLS
Well, so far I got:
a complete set of metric wrenches,
a medium size set of racheting wrenches,
OBD II reader,
strut spring compressors
front end service kit,
metric set of crows foot wrenches (flare type) with set of flare wrenches,
swivel head rachet,
other small dollar miscellaneous items
Thanks for all the advise so far. I think I'm done stimulating the economy for now...
OBD II reader,
swivel head rachet,
2007 Chevy Cobalt
Re: TOOLS
Add me to the 'welder group'; that's what I'd throw a grand at today. (I could use more air tools, but overall my tool collection is fairly complete.)
- I am merely driving my van
Re: TOOLS
No tool kit is complete without a fifth of Jack, (for after the work is done obviously).
2003 awd cargo g80 3.42 gear
1998 awd 230,000 R.I.P.
1992 awd 240,000 R.I.P.
"What? Me worry?" Alfred E. Neuman
Re: TOOLS
i don't know.... some of those job are so annoying it helps to take a break(and a shot) while working then take another run at it
Re: TOOLS
I know this is an old thread, but I am a new owner of an old ('98) van.
I have a very good and complete set of tools, from many years of professional (mostly import) wrenching, but the one thing I found surprising with the A/S vans is the need for 18mm sockets and wrenches. Many tool sets skip the 18mm size. Trying to remove a front seat without an 18mm socket (preferably a deep one) is pure torture, and if you have the passenger side under seat drawer, it is even difficult with a deep socket.
There are several other places where the correct metric socket is the only thing that works reasonably well.
The early (American version) Ford Escorts seemed to use a nasty combination of SAE and Metric size hardware, and to remove a cylinder head it seemed to need one of everything the the tool box. That was the first time I had ever needed ( or seen) a 16mm wrench or socket. Leave it to the US manufacturers to go down a different path with their metric conversion, instead of adopting either the Japanese or the German (DIN) standard, both of which have been well used for many years, without the need for a 16mm or a 18mm size.
Rod J
Issaquah, WA
Rod J
Issaquah, WA
WE7X aka Rod Johnson
Issaquah, WA
Issaquah, WA
Re: TOOLS
Yes tools, tools, tools,
Now we need Torx and Torx female for some fasteners. Seat belts, etc
- Has thanked: 12 times
- Been thanked: 4 times
Re: TOOLS
21mm and 22mm wrenches or sockets are also needed for the rear suspension (shackle bolts, etc.), IIRC - which were two that I needed to go buy specifically for the van.
For tight spaces (under seats, etc.) I've found my craftsman ratcheting combo wrenches to be key. You can do the job with regular open wrenches, but sometimes the limited space means you're re-seating that box 50 times...
I've made a habit of keeping *all* tools I need to work on the van in the bloody van. Any time I find a job that can't be done with the on-board tool set, I move the tool over then buy a 2nd one to keep in the garage.
Re: TOOLS
Yes, I agree, that is a very good plan; particularly for those who usually try to do their own work and travel very far from their home base.
I some cases you may have to get towed to some place where parts are available, but at least if you have the correct tools, the repair can be done.
I spent a couple of days working on a dead VW in the parking lot of a cheap motel in Canada. The motel was conveniently located just a half block from a tool rental shop, who had floor jacks and jack stands. Parts house was just two blocks away. Beer and food across the street.....nice little town!
Rod J.
Rod J.
Issaquah, WA
Issaquah, WA
Re: TOOLS
Herbie and all,
Yes it is 21mm nuts/bolts on the rear spring shackles, and the 18mm shows up again on the rear spring to axle attachment bolts. I found I have no less than five copies of the Craftsman (or better) 18mm combination wrench. Some look to be unused.
I guess they will become used very soon.
Rod J
Rod J
Issaquah, WA
Issaquah, WA
